Brief Description: Nose rib stiffener angle prep, epoxy prime nose ri
I drilled the holes for the nose rib stiffener angles. I then gave them the same preparation and Alodine treatment for priming. I epoxy primed the nose ribs and stiffener angles. I sprayed 2 light coats of epoxy primer. I actually used more than I anticipated so had to mix a couple of batches. I also realized I'm going to need more than I have on hand so I order more right away.
