Brief Description: Deburrer lightening holes and flange the back ribs
With 2 birthdays in our house today I'm lucky to get even a couple hours in. I was able to finish deburing all the little rib lightening holes and flange the 4 rear ribs. Flanging the back ribs with the John Rheney type dies worked perfectly. There was no need for any other work other than just a slight bob stick to flatten the rib.
The 4 back ribs are done.
When you build an airplane in your garage the neighbors are usually curious to what you are doing.
