Brief Description: Connect brake pedals to rudder pedals
I finished cutting out the tabs for the brake pedal attach points. I made a template to mark the center point of the tab location on the rudder pedals. Its 40 degrees rotated back from top center. Then I bolted the tabs to the brake pedal to position for welding. I used another idea from Russ Erb and used a long bolt with a bunch of washers to prevent the nut from locking on. I used some safety wire to hold the brake pedal tight to the rudder pedal and used a clamp to hold the tabs centered on the 40 degree position mark. After tacking I cut the safety wire off and removed the clamp. I kept the brake pedal bolted to the tabs for welding. I welded the first two pedals.
