Reinstalled the bending blocks and bend down the top tab over the previously bent bottom tab. finished it off by hitting it with the flush set. The bends turned out really well. The completed bend line is straight and uniform and perpendicular to the trim tab spar. The top surface tab is bend down over the bottom tab in order to shed water.
