Christophers Web Site
Date:  7-31-2020
Number of Hours:  75.00
Brief Description:  Paint
7/1 4
Prepped garage for paint
Primed and applied basecoat to ailerons, lower cowling and front deck
7/2 4
-Taped off lower cowl and added blue basecoat
-Clear coated ailerons, lower cowl and front deck
-Primed upper cowl
-Messed up first coat of base due to forgetting to spray out residual lacquer thinner. Will fix tomorrow. Third times a charm.
7/3 4
Sanded and epoxy primed left wing
Finished paint on top cowl.....so much trash and a big clear run.
7/4 1
Wet sanded trash on left wing
Started wet sanding front deck w/1000
7/5 3
Finished basecoat/clearcoat on left wing
7/6 3
Sanded and buffed left aileron
Started right one
Floxed in new nutplate on right wing
7/7 2
Sanded and buffed right aileron
Sanded out run on top cowling
7/8 2
-Sanded and buffed lower cowling then dropped it on the driveway and ruined the paint
-Started sanding left wing with 1500
7/9 4
BL wing sanded to 2000
TL wing 99% done w/1500
7/10 2
Finished left wing sanding
Patched right wing hole
7/11 2
Filled wing patch
Worked on balancing right aileron
Made mold and melted lead weight
7/12 2
Drilled and mounted weight
7/13 2
Clearanced wing for counter weight
Glassed wing cutout
7/14 3
Epoxy primer applied to wing
7/15 1
White basecoat painted on right wing
7/16 3
Painted blue tip and clearcoated wing
Started fabricating tachometer bracket
7/18 1
Drilled bracket holes
7/19 2
Finished bracket mounting and wired sensor
7/20 2
Made lead block for left aileron
Drilled and balanced aileron
Clearanced wing for counterweight
7/21 2
Finished counterweight
Glassed cutout
7/22 3
Trimmed fiberglass cutout
Buffed lower left wing
7/23 1
Wet sanding top cowl
7/25 2
Wet sanding right wing
7/26 4
7/27 2
Finished wet sanding
7/28 3
Buffed lower side
Took wings to airport
7/29 2
Prepped/painted rudder and tail fairing
7/30 3
Primed fuselage
7/31 6
Painted fuselage
