Christophers Web Site
Date:  11-15-2019
Number of Hours:  20.00
Brief Description:  Speedbrake and seat belts
10/27 2
-More intake work
-Fabricated right seat belt attachment
10/28 3
-Finished seat belt brackets
-Cut and glued ply for speedbrake
-Trimmed intake shroud and added pads for camlocs
10/29 4
-Cut speedbrake and riveted hinge on
-Cut hinge brackets for inside
-mounted brackets
-Drilled hinge and mounted to fuselage
-Riveted camlocs on intake
10/30 2
-Worked on speed brake actuator mount
10/31 2
-Clearanced seat for added brackets
-Installed seatbelts and brackets
11/3 1
Speedbrake work
11/4 .5
Made dust
11/6 1
Cut and fitted right air vent
More dust
11/11 .5
Speedbrake work
Dust
11/12. .5
Glued upper bracket for speedbrake
Dust
11/13 .5
Trimmed upper speedbrake mount
11/14 .5
Fabricated limit switch bracket for speedbrake
11/15 2.5
Cleaned out shop
Microed upper left wing
Glued limit switch bracket
