Started the process of installing the rudder peddles. I choose the ground adjustable option years back. Now I'm wondering if that was a good choice. To adust the peddels on the ground you must remove 4 bolts in the rudder peddle area, not easy to get to, and change the straps which connect the rudder cables to the peddles. So you have to have shorter and longer straps to change the position. Now I think I'll be the only one flying from the front seat so the only issue would be for resale.
