Worked on the Rudder pedals and mounting hardware. Drilled the angles and made the thrust washers. Mated the axle to the pedals the measurement from floor to brake is exactly 1", the over all width is 15 5/16", one sixteenth over the plans. Set them in the fuselage and they look like they will fit nicely. I'm toying with making them removable so the adjustable pedals could be installed at a later time. This means installing plate nuts to mount the angels. Thats a lot of plate nuts.
