continued work on fitting the F899 L to the left side. Decided to make the bends a little tighter. Well doing so I cracked the sheet. So now I need to regroup. The crack is at the top of the part. I have a few options, buy more .025 2024 T3 aluminum or cut the top part off and rivet an angle to it. The angle will be faster but not as pretty. I could do the rivet and always make another one later. This might be the best option so I can get moving.
