I've been toying with the concept which has been done before. That is to create a sister cover to the F899. this cover sits under the forward baggage compartment on the right side. It creates an area of extra storage. The concept is to create a symetry by adding an F899L. this cover would protect the fuel boost pump and filter from inadvertant feet impact. Additionally it would create an area which seperates the fuel pump and filter from the feet of the pilot. I plan on venting this area to the outside so any errant fuel vapor will be safely vented overboard away from the occupants.
