Continued fitting of the Gear weldment and the position it has in relation to the F843 lower longeron. the right weldment brace extends to far out board and pushes F843 out of alignment. The distance by the plans is a gap of .0635 for the F895B doubler. The doubler sets inside the F843 and is sandwiched between the F843 and the gear brace. I will need to remove a little bit of material from the F890 floor skin where the gear extends through. Fitting the weldment is a little tight and removal of .032" will releave this.
