Worked on the landing gear weldments and the mounting of the F843. One of the holes that is supposed to clear a rivet on the center section is not in the correct position. So I had to grind away enough material to let the weldment sit flush on the center section. I'll do the right side tonight.
Hung the new plumb bobs and the alignment is near perfect from the F807 to the firewall. Very confident now that everything will line up.
