Ok, with the new C/L set, I started putting in the F843 lower longerons and had to rework the F887 upper longerons. cut the eliptical opening for the WD gear mounts in F843 and cleaned up the floor openings. the right gear WD needs to be bent to match the F843. I need to make shims for the mount and F804 to F887 position. I feel like I'm ready to drill the F843 to WD803 holes and start making a fuselage. "About Time".
