Tom's Web Site
Date: 11-15-2009
Number of Hours: 6.00
Brief Description: Cowl top II
Cutting, filing, fitting, filing, fitting..... tight fit around the tubes.
Working on getting the side panels to fit a little bit better. Door hinge slots are the pain. Hindsight, cut out 1/4" slots, then rivet small plate over the hinge openings would have worked. Lots of little trimming around the fuel lines coming down the post.
Top cowl. Panel is Cutting, filing, fitting, filing, fitting..... tight fit around the tubes.
Top cowl. Panel is removable (leaving front portion) to give lots of access to avionics/electronics behind the cowl. (leaving front portion) to give lots of access to avionics/electronics behind the cowl.
file helper -- scrap wood with holes
top cowl
access panel removed
