Brief Description: Left Door Interference with cowling overlap
Overlap behind the door post is 0.600". Should be 3/8" to 1/2" (need to triple check). You want some overlap for a wind seal, but door it hitting (unable to close) with current amount overlap.
With tie down straps holding everything, surprisingly solid feeling to the sheet.
