PIC One shows how I did the floor for the PIC and Copilot. Two pieces. Notched area is for the control stick. Floor section (all the way across) at the top is up against the rudder control. There is a 1/2" flange there. Also small notches to clear the rudder pedal mounts. No need to remove rudder pedals, nor stick during inspections.Notice the small filler plate that will go around the flap handle. There are two "half circles" to clear the flap handle when all the way down.Remainder of floor, under rear seat and all the way back to cargo area are two sides. Right and Left.
floor boards.
under rear seat and cargo area. Split Left & RIght
