making small filler plate near flap handle. Need to order fuel valve, to make sure it will clear the flap handle. Started to install the lower trim piece for the cowl tunnel. Tabs are shared with the floor boards, so need to add a method of holding trim in place with floor boards are removed. Added some nutplates (10-32) to this piece as the monadnock clips don't work in this location.
