Tom's Web Site
Date: 6-24-2012
Number of Hours: 4.00
Brief Description: Tabs and nut plates
Tabs above foot wells.
Idea is one, or two, sub panels in those locations. Fuse boxes, relays, electronic stuff. Thinking of a hinged side, with the fuse panels being on the top of the panel. For acess, remove two quick release (Dzus?) fasteners. Drop Panel, inspect and replace fuses.
If a fuse blows mid flight, typically there is a reason so debugg once back on the ground.
Airspeed, Altimer, Vertical Speed steam gauges.. and a Wiskey Compus are all functional without electrons.
