Brief Description: More welding - brake line supports
Removing the AN742 clamps as I go, replacing with welded tabs. Fuel selector valve.
1" wide 4130. 0.060" thick.
Cut a 2" long piece, marked two holes 1" apart, about 1/2" from end. Drilled on hole for 3/4" tube, other hole was approxiamately 0.450" (just one of the Unitbit steps) for -3 Bulk Head fitting.
Brake line support --- when it goes from rigid line to flexible hose. Hose allows movement of landing gear, but avoid biding on "unscrewing" of the hose from movement.
