Brief Description: Riveting and completeing the trim tab server mount
I gave the parts a quick primer squirt and came back Monday to assemble it. Just a little back riveting (remember to set the air to 37 psi for those 3-3.5 rivets!) with the new Avery back rivet set. Came out nice with a flush surface on the outside of the plate. No parasite drag there!
I didn't find anything about what torque the 4 mounting nuts and bolts were supposed to be for the corners of the servo. They had nylock nuts on them so I just screwed them in snug since the servo was plastic, there was no need to crank it down really tight.
