Brief Description: Dimpling elevator skins and ready for primer prep.
After holes are all drilled and deburred, they are dimpled. Again this was really easy after I learned that if you use the male end of the dimple die on the top of the DRDT-2 rather than bottom, you can avoid scuffing up your shiny parts while poking around looking for the hole. Peeled off the plastic and that part is done.
