Just some notes on the trim tab plate. Ours will have the electric trim by the way. The plate is dimpled and drilled like anything else. The only thing different is that it says "dimple the #6 screw holes" Uh....do I drill that to #6 also? There are some rivet-on clips to thread the cover plate screws through. I was looking at it backwards and drilled the #6 hole then dimpled it. Don't do that. Just dimple with the #6 dimple die. The screw is smaller and will fit through fine, I was just looking at the screw mount backwards. No harm done, nothing too structural, just learned another thing through a minor mistake.
Finger points at the #6 hole I enlarged. No need to do that as seen by the other dimipled holes.
