Traci and Tom's RV-7A
Date:  8-29-2013
Number of Hours:  0.50
Brief Description:  The forgotten R-918 pieces
1 am this morning I was studying builder sites on the trailing edge method. I then noticed that another guy had a familer part on the bottom of his rudder that mine didn't have - the R-918 pieces that I had to fabricate. A few moments of cussing then a trip to the basement to confirm.
I have no shame in sharing my mistakes if it helps another builder, so her it is. I did see another guy did the same thing, so I'm not alone.
I had no problem removing most of the rivets, but I had questions about the blind rivets since the manual said to "install carefully since they are hard to remove". I had an idea - what if I cut a groove/notch to fit the part around the shop head of the blind rivet? Or would it be easy to remove? I did ask advice and got mixed replies. I asked Van's and they said it would probably be fine. I put it aside to think about while working on the elevator.
This part should have been installed under here.
The scary blind rivet, is it hard to deal with?
Could this be notched possibly?  Asked Van's.
