Traci and Tom's RV-7A
Date:  8-1-2013
Number of Hours:  3.00
Brief Description:  Skin HS601PP riveted to HS708 and rear spar.
I got a lot done today on the horizontal stablizer. I'm getting a lot more comforable with the riveting now. I can get about 20 in a row hammered in well, with an occasional screwed up rivet that needs to come out.
Seem that sometimes when you have one of those that sticks out a little, it can still be salvaged with a little extra pressure on the rivet gun to work it down in the hole. Don't just hammer on the thing without a buck bar behind, I did try that with a bar behind the rib, but still endede up with a minor crease in the skin, so if it goes badly, just drill it out.
I had one out in about 3 minutes with a clean hole left behind so I'm getting a lot more confident with this critcial skill! Originally, I was thinking of counting my removed rivets like I have seen one builder do, but I lost count after 15 so that idea was abandoned.
After the rivets were in the skin as mentioned in the manual, I temporariliy clekoed the rear spar on to carry it out back for another squirt of primer on some of the suffed primer from the buck bar - I find that it's pretty hard to avoid some scuffing!
Looks like I'm soon on my way to the vertical stablizer. This is a LOT of fun once the fear of the riveting (and removal) has been mastered - or at least improved to a less scary level! :-)
Alternating rivet installs for a tight fit Rivet tape holding them in place.
One of the
One of the "oops!" rivets that went in wrong. Easy fix now.
Rear spar on for carrying upstairs.  Just some primer re-touching.
