Traci and Tom's RV-7A
Date:  7-31-2013
Brief Description:  Another challenge - fix for the mis-dimpled hole.
If you refer back just over a month in the log, you'll see the mistake I made with dimpling the skin. (The common goof that most builders make!) see here - http://www.mykitlog.com/users/display_log.php?user=tomtraci&project=2260&category=9013&log=172804&row=12
I originally had the idea that I had already put in the dimple and the "bounce" I did was where I poked that incorrect hole. Now that I got to the skin riveting, I found that the dimple din't line up with the hole. The un-dimpled hole was really the factory hole in the first place. Closer inspection I could see that the other hole was out of liine with the rest anyway. Ok, now what?
I posted my photos to a local builder list and got some adivce. A friend suggested that I use a spoon and bucking bar on the back to push the dimple down, re-dimple the correct hole, then use filler when painting time comes. (Many other suggested the same thing about a month ago when I originally did this mistake). It took some careful pounding with the spoon (it was one of my older mis-matched spoons, not one of Traci's good ones!) and a bucking plate underneath. Finally got it down fairly flat and re-dimpled the correct hole. Next thing is the filler, but another builder friend told me that the paint shop frequently fills things like this as part of the prep process.
Good hole is the left one.
After moving the dimple and riveting.
