Traci and Tom's RV-7A
Date:  7-2-2013
Number of Hours:  0.70
Manual Reference:  DWG 7 - Stiffener
Brief Description:  Cutting the R-915 stiffeners
Pretty simple step. Just look at the diagram closely to see how the rudder stiffeners are cut out. There are 8 strips that cut apart into 2 stiffeners each. The holes make it easy to figure out, just cut center to center of each hole. Just study the cutting diagrem and start cutting them apart.
After the cut.  This is the end before the taper is cut.
R-915 stiffeners eventually will go here.
