Brief Description: Connecting the Servo to the Trim Tab
Fabricated the elevator control horn and clecoed the servo inside the elevator. Next, measured and cut the linkage arm to the desired size and installed both clevises. I lined up the linkage with the control horn attached and marked the location for the rivets to attach the horn. I drilled and clecoed the horn using #30 cleco. I will go back and redrill these to 5/32".
