Brief Description: Finished rivetting left elevator
Rivetted trim tab hinge and trim tab spar to right elevator. Back-rivetted left elevator trailing edge. Rivetted remaining three rivets on both tip- and root ribs. Managed to get both aft rivets in with AN426 rivets through very careful squeezer operation. Rivetted the remeining rivets on right elevator tip- and root ribs.
Next: Backrivetting right elevator trailing edge.
Finished trim hinge on left elevator.
Set both most aft rivets on tip rib.
Flat top trailing edge. The bottom one is a bit wavey.
