Brief Description: Matchdrilled right elevator skin to spar and ribs
Matchdrilled the right elevator skin to the spar and all ribs (root, tip and counterbalance). Matchdrilled the ribs to the spar. Deburred the tip- and counterbalance-rib, partly dimpled the tip- and counterbalance rib. For the elevator tip rib at the most aft points used the pop-rivet dimpling tool. The dimples were not deep enough, used the machine-countersink tool for the correct depth. Worked fine.
Next: Fitting the elevator horn to the spar and the root rib, deburring the skin.
Right elevator matchdrilled (except for the trailing edge)
