Brief Description: Match-drilled the rear HS spar; Deburred HS ribs
Match-drilled the HS-906 Rear Spar Doubler with the two HS-903 Rear Spar. Match-drilled the HS-912 Outboard Hinge Brackets to the rear spar (sorry, no photos).
Deburred the lightening holes of the HS-904 Main Ribs. Deburred the HS-905 Nose Ribs, straightened all the flanges.
