Brief Description: Deburred and straightened HS-904 Main Ribs
Deburred the HS-904 Main Ribs, with grit 400 sandpaper the tine relief cuts, with the scotch-brite wheel the remaining edges. Fabricated HS-909 shims out of AS3-040 sheets supplied. Match-drilled to the front spar.
