Brief Description: Getting back into the swing of Building
Getting frustrated with the rivet sizes for the rudder control surface spar. I have now burned through three squeezed rivets on the first rib and can't get a good alignment with my hand squeezer. I also found out the rivet size called out are too long for the application and the next size down is too short so I will have to file down the rivets for this one rib. Going to look at getingt the right rivet squeezer for this tight spot.
Decided to move on and do step 4 on 07-03 and step 1 on 07-04.
