Brief Description: Rudder Spar Assembly Construction
Finally getting back into the build, had too much work going on that kept me from having spare time to work on the plane. Today I worked on the rudder spar assembly match drilled all reqiuired holes, deburred all drilled holes and spar. I was able to match the hinges on the vertical stablizer - so I did it right. Ready to move on to the control surface ribs and skin next.
