Actually worked on a Saturday this time. Installed the forward skin on the vertical stablizer and mounted the upper hinge assembly. Wired up the lower hinge assembly according to the instructions. This completes Section 06-07!! Ready to move on to Section 07.
Forward skin mounted.
Inside shot of the forward skin screwed into the nut plates.
his is the upper hinge assembly mounted to the vertical stablizer..
