Brief Description: Rudder Spar Cap - upper and lower Cont.
Continued working on the rudder spar components. Laid in the upper spar cap plates with the match line visible through the pre-drilled hole and clamped. Clamped and match drilled four of the #30 holes to hold both the right and left upper spar caps in place.
I mark the plates at both ends to confirm the position for match drilling.
Right upper spar cap in position and ready for additional match drilling.
