TIMOTHY'S WEB SITE
Date:  7-18-2017
Number of Hours:  1.00
Brief Description:  Rib Jig - Cap Strip Former
I had previously cut out the top cap strip former for bending the top cap strips after steaming them. The top cap strip has the most severe curves. I exaggerated the curve at the top by about 1/2". When I took the cap strips out and placed them in the jig it went well. The fit into place without much effort.
I tried to use un-steamed bottom cap strips. It worked, but they were somewhat difficult to slide into the jig. So I decided to make a former for the lower cap strip also. I steamed a couple of cap strips and they fit into the lower cap strip location very easily. Glad I took the time to make the lower former also.
The upper former was made from 2-2x12''s, planed flat and glued together.
The lower former was mad from 2-1x8's. Not as much curve.
I made extra prints of Bernard's large, long rib layout and glued them to the former for cutting the curves.
Rib Jig with Clamps
Rib Jig with Clamps
Bottom Cap Strip Former
Top Cap Strip Former
