After I completed "The Big Jig" table and "Web Cutter",I got back to work on the rib jig.
I added the clamps so they were convenient to the gusset plate. I used 1/4" carriage bolts from the bottom with washers and nuts to keep them tight to the jig board. I have wing nuts at the top to tighten down the clamps.
I will set up for gluing after I get the gusset plates cut.
