I got a lot done today on the right-hand wing spar/SNX-W08-01R. I finished drilling the pilot holes in the upper and lower spar caps. I layered up the rest of the other spar webs (SNX-W10-02, -03, -05) and cleco'ed them together with the spar caps. I also drilled and cleco'ed the tip web assembly to the spar. Next, I pilot drilled and cleco'ed the end wing attach assembly (SNX-W11-02) and the lower angle (SNX-W11-01). Onward!
Spar caps drilled and cleco'ed to the main spar web.
Other spar webs layered-up and cleco'ed to the spar.
