I completed the right rear wing spar today. I used the wrong size rivets on the tip rib attach angle and had to drill those out and use the correct rivets. Other than that, it went together OK with no problems. Now on to the left spar.
Right rear spar all up-drilled, deburred and ready for riveting.
