Brief Description: Left rear spar and other parts.
I finished the left rear spar today. This was similar to the right rear spar except that the left attach plate mounts to the other side of the spar channel. Also, the left root rib attach angle needs to be set back from the edge of the spar channel by 0.025".I accomplished this by taping a piece of scrap aluminum to the outside face of the attach angle to use as a template for the set-back. This did the job fine.
I also worked on some parts for the main spar. I made the shim plates (SNX-W11-04) and I rough-cut the wing attach blocks SNX-W11--03).
Scrap piece taped to attach angle face to provide 0.025" set-back.
