Brief Description: Leak test Left tank, Install access panels an nutp
Had installed the leak test fittings on the left tank the day before. 24 hours later, Balloon still inflated, no leaks. Next was to install the access panels with nutplates on the leading edge skins. These access panels will allow me to access the Fuel Bung on both tanks as well as the later installed extended range tank fuel pumps.
