Brief Description: Final assembly of left wing tank
Picture 1 is of the finished baffle installation of the left wing tank. I had to close up the normal pick up fitting hole with a plate to cover the rivet holes for the anti rotation bracket, as well as the fitting hole. I then installed the fuel sender. Pic 2 is of the completed left wing tank all sealed awaiting curing time to leak test. Pic 3 shows the vent fitting, an the flop tube fitting at thru the tank attachment bracket. On the bottom is the inboard most Z bracket
Left tank baffle with sender installed
Left wing tank completed
Left wing tank fuel pick up fittings and vent fitting
