Brief Description: Fly cutting access for Right wing tank sender and
Fly cut the Right tank rib for the fuel assembly ring. Used a die grinder to debur the newly cutout. Clamped the cover plate on the opening as per instructions to allow the sender to be installed in the proper orientation. Only one way it will work. Drilled the cover plate to attach the attachment ring.
Fly cutting for right tank fitting
used a die grinder with scotch brite disk for deburing
