Brief Description: Making attachment angles and checking for vent tub
Match drilled the Usher tank caps on right wing. Made the tank attachment bracket for both tanks at the same time along with the doubler for the inside. Picture 3 shows the flop tube purchased from Vans for the Left tank. I will have to modify the end rib to accept the fitting for the flop tube.
