Brief Description: Preassembled wing spars and ribs left wing
Clecoed the main wing spar, ribs and rear spar for the left wing. Match drilled all holes in spars. Left clecoed together. I plan on final drilling the 1 x 1 x 1/8" angle for the wing jig so I can place on jig to allow room toPre assemble the Right wing spar the same as the left. That way, I will number each wing rib before dissasembly to alumi-prep, aloding and prime. I plan on using the Sherwin Williams Wash primer on the interior of the wing for corrosion protection. The wash primer is like spraying water on and dries about as fast.
Left wing rear ribs and wing spars clecoed together
