Brief Description: Used pro seal to attach the items listed in the pi
Mixed up the 2.5 oz proseal to attach the fresh air vent to the forward fuselage. Since I had to mix the entire tube of proseal, I decided to attach the rear seat fuselage vent and the static air vents also. Wasn't sure if there would be enough proseal, since this was the first time I had used it. I also, had purchased the semco pneumatic dispenser from Brown tools. No time like the present to try out the semco. After mixing in the 2.5 oz tube from aircraft spruce, I transfered the mix into a 6oz disposable tube that fits the semco. I was pleased with the workings of the semco pneumatic. It dispensed only the amount needed, and stopped when the air trigger was released. This was for reference of how and what to expect when I use it on the fuel tanks. Worked great. Only thing I was not expecting was, after applying the proseal to the Items listed, I still had almost or at least 2 oz of proseal left. I see now, this stuff goes a long way.
