Brief Description: prepped front skin for attachment
Removed the protective cover from the inside of the front skin. As per plans instructions, I removed the hatched areas from the skin. I used a dremel tool with a reinforced cutoff disk. Finished up the edges with a round rotor file in the dremel also. Deburred all the edges. Attached both the aft and forward baggage door strips to the underside of the skin with 3 clecoes each. As per plans, started at the center and worked down clecoing across and down to achieve the curve of the bulkheads. Clecoed all holes and then removed every other one for match drilling with a 40 reamer.
