Brief Description: Install forward wind screen roll bar
Final installation of forward wind screen roll bar. I see at this time that the static line that I had previously installed forward grommets are 1/4" and I plan on using the same location to bring the wire from the trim servo and nav lights on the rudder. I will have to remove the 1/4" grommets and use a step drill to enlarge to a 5/8" snap bushing. Now is the time to get this done. I also cut the back boards for the rear turtle deck
