Brief Description: Outboard brackets trim adjustments
When installing each gear leg, the outboard bracket had to be trimmed to allow for movement for and aft when final toe adjustment will be made. I used a drimmel tool to open up the bottom skin material around both outboard gear mounting brackets to allow for final adjustment with gear installed.
