Brief Description: Grove gear mounting brackets set up
Seperated mounting brackets for Grove Airfoil Gear. Installed center bolt in inboard gear bracket. Placed in drill press to match drill 5/16 bolts thru inboard wear plate. Final hole prep with 5/16 reamer to full size. Followed same procedure for opposite gear leg. All inboard brackets drilled and reamed.
